Old 01-04-2015, 09:10 AM
nikster's Avatar
nikster nikster is offline
Default Terra-grip. Update
1st. Things first.
My drive way is as flat as you can get!
In my opinion; chains are a bit better. I had to anticipate & think ahead to do my plowing of 2" of snow.
I did start spinning a few times at first. Thinking ahead I had to change my tactics being used to chains.
So, all in all if you've got a flat drive
They are OK., but I think with a sloping drive one can run into problems ???
Also my driveway did not get scraped up.
There-ya go.
NIK,
Old 01-06-2015, 11:58 AM
nikster's Avatar
Default More update
Ok, we had about 3/4" of powdery white stuff fall during the night. Went out there to clear my F L A T drive & a true test .
As I wrote before; chains worked better.
How can one get stuck on a FLAT drive? Easy. Go to back up & rear tires were spinning on 5 occasions. A bit of snow fell onto the front of the front tire in backing up & that was enough to start the rear tires a'spinning. Had to get off, clear the obstruction, pull the tractor a few i inches, rock it back & forth to get traction again. I'd hate to think of the problems with any kind of incline.
End result, I wish I would have saved the money.
Gonna order some chains.
Nik,
With the bit of scrapping my asphalt drive takes with chains, I'll live with it.
Old 01-06-2015, 12:50 PM
Well that sux, I was hoping that they would work out for you.
Old 01-06-2015, 12:56 PM
j4c11's Avatar
j4c11 j4c11 is offline
That's why they're called terra-grip and not nix-grip.
cubs-n-bxrs's Avatar
I kind of wondered how they would work on a smooth driveway. I bet they would work much better on a gravel driveway or dirt.
Old 01-06-2015, 01:11 PM
The only point to the terra grips is you can use them on asphalt without chewing it up, I don't think people with gravel driveways care about scratching the rocks.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 01-06-2015, 01:28 PM
Sounds like you need more weight Nik.
Old 01-06-2015, 05:06 PM
nikster's Avatar
? Weight?
I'm 275 + 60 lbs. more on the rear . I would think that would be substantial???
Nik,
Old 01-06-2015, 05:42 PM
? Weight?
Nik,
Have your wife come sit on your lap while you work. Then you can have "together" time. Girls like that.
Old 01-06-2015, 05:45 PM
Nick,
I guess they worked Terra ble
Up to 534 and counting...
