I am disassembling a Magnum 18s engine. When I removed the flywheel, the magnets on the inside were attached to the stator. None of the magnets were damaged but I cannot tell how the magnets are attached to the flywheel. The oil seal under the flywheel has been leaking for a very long time and everything is oil soaked. Are the magnets held in place with an adhesive?
Thank you! |
The magnets are epoxied to the flywheel. You can clean every thing up and re glue them but the magnets have a north and south pole and have to go in the proper orientation and I forgot what that is. I'm sure someone smarter than I am will chime in.
![]() ![]() In addition to what Sam said, IIRC, the spacing of the magnets is critical to get the proper voltage output.
Found this with a Google search
https://www.youtube.com/watch?v=DUGK_H-Sulc Pretty sure he works at the local Cub dealer. He makes my head hurt ![]() At least his info is correct as far as I know. ![]()
I had the same problem except 2 of the magnets were destroyed. I replaced them with come magnets from epay. The magnets were slightly shorter than the originals were thick, but they were much more powerful. The repaired flywheel worked exactly like a stock flywheel, same voltage and current. Just be sure everything is cleaned and the JB Weld is mixed well and the poles are arranged N-S-N-S-N. The original magnets are 2 types, N-S-N and S-N-S. Here is a picture of my repaired flywheel.
Richard |
![]() Quote:
Well I got a laugh and an education at the same time. Billy Bob teeth and a dozen pens in his pocket made me wonder at first if this was a joke or not! Thanks so much for the link and the advice! |
I gotta know, are those toofis's real , and does he have more pens or toofis's?
That reminded me of the scene in " Deliverance " where the queer hillbilly tells Ned Beatty ; Now you just go ahead and drop them there britches and squeal like a little piggy boy. Seriously tho , that was edjumacational and funny. Something tells me those toofis's are real tho. Chris
1968 104 , service replacement '96 K301, 42" deck 1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck 2007 LA130,21hp Intek v-twin, 48" deck ![]() ![]() |
