Old 01-16-2015, 09:02 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default M18 Governor Pinning
I have an 1872 and my father has an 1862. Both tractors have the Kohler M18 engines in them and I do not believe either of them have had the govs pinned in them. Can I pin the governor in each of the tractors without removing the engine?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 01-16-2015, 11:39 PM
mobermiller's Avatar
mobermiller mobermiller is offline
I know you'll have to remove the air duct from the pto side of the engine. The governor shaft is next to the oil fill tube.
Old 01-17-2015, 12:41 PM
Yes, you can.
I'm not sure I'd worry about it. It's easy to see. Just make a quick glance at it when you check the oil to make sure it isn't working out. I've got an M18 with nearly 1000 hrs on it.... it's never moved. But, it's pretty easy to do just for piece of mind if your worried about it.
Old 01-17-2015, 04:14 PM
If I remember right, that Kohler service bulletin to pin the governor was for engines built in a specific time frame, wasn't it? As old as these engines are now, I'd think if the governor hadn't worked out by now, it wasn't going anywhere?
Old 01-17-2015, 04:38 PM
I believe that is correct Mike.
I tend to agree also.
Old 01-17-2015, 08:32 PM
FrankF3's Avatar
Thanks guys, I guess you're right. Why look for trouble?
Old 01-17-2015, 10:23 PM
gdheck's Avatar
gdheck gdheck is offline
Anyone have a link to the service bulletin? I can't seem to find it.
I assume that this can also happen on the Mag 20's?
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 01-17-2015, 11:14 PM
RLause's Avatar
RLause RLause is online now
Hello. I just happen to have it. I went thru this several months ago.
Richard
Old 01-18-2015, 12:02 PM
gdheck's Avatar
Thanks,
I had never seen that before.
Old 01-18-2015, 12:09 PM
Just make sure you use a long enough pin to be able grab it to remove it in the event you need to do so!
