Old 01-20-2015, 07:15 AM
CubCadet129 CubCadet129 is offline
Smile Best SGT
I have a question, what is the heaviest duty Cub Cadet, and is it an SGT? Also, do any SGt's have a cast iron rear end, and do all SGT's have a fine spline rear axle?
Thanks
Kyle
Old 01-20-2015, 08:32 AM
Thanks
Kyle
I can see this one going bad but I'll take the bait.
1st: 982's below serial number 719999 had a cast iron rear.
2nd: Pretty sure the SGT's with the aluminum rears have the fine splines
3rd: As far as heavy duty goes biggest difference between a GT and a SGT is frame length, front axle and larger tires.
Old 01-20-2015, 08:57 AM
j4c11's Avatar
j4c11 j4c11 is offline
Kyle
Including the Mitsubishi/Yanmar produced ones or just IH/CCC/MTD?
Old 01-20-2015, 09:09 AM
cub123's Avatar
cub123 cub123 is offline
Sam
Its hard to name the "best" SGT , yeah, the early 982 have a cast rear, and are over all tough as nails, but... they don't have power steering or fine spline axles and have an Onan in them. The later supers are great with power steering ,fine spline axles, and could had with a diesel. That said I wouldent ruel out one with the aluminum rear, I've run mine hard even without the Xtream braces, but with them I'm sure you wouldent ever have an issue.
Old 01-20-2015, 10:24 AM
The best one is the one you own...
Old 01-20-2015, 10:49 AM
Smile
Mitsubishi and yanmar only made the CuT's and ScUT's, correct? I am talking about super garden tractors only so if they made super garden tractors then I would include them but if they didn't then I wouldnt.
Old 01-20-2015, 10:50 AM
Thanks for all the help guys and have a nice day!
Kyle
