Old 01-21-2015, 10:41 AM
crossingcrown's Avatar
crossingcrown crossingcrown is offline
Default Ross steering mod
Any body ever install a Ross steering mod kit? I see it is replacing a nut for a bearing system.. I still don't really understand what it does.. Or how it helps.. Any body, ???
I am broke, but I make it work!
Old 01-21-2015, 10:50 AM
gt383mag's Avatar
gt383mag gt383mag is offline
hey check this out
https://www.youtube.com/watch?v=x9rGA_BePMo
Old 01-21-2015, 10:55 AM
tservice tservice is offline
http://youtu.be/qIxYUmPLRzM
Old 01-21-2015, 10:56 AM
I watched this vid before I posted, this is kinda what sparked it.. it still doesn't say how it helps.
Old 01-21-2015, 11:18 AM
gt383mag's Avatar
that little thrust bearing takes out friction in your steering system. have not personally used one but heard it does help reduce steering effort
Old 01-21-2015, 12:16 PM
Think of them as a little "Lazy Susan".
I normally put one in, when I rebuild a column. IMHO anytime you can reduce friction or drag in the steering system, there will ultimately be less wear.
Old 01-21-2015, 01:24 PM
red56turbo's Avatar
I put one on my 782D when I rebuilt the steering a couple years ago. Since I had to replace stuff, I went with the bearing setup. To be honest, I don't really notice too much of a difference. Now when I hop on a Super, I notice the difference...........
Under edit, I agree with Yosemite. Works like the Lazy Susan concept and does reduce wear/tear. If you have to rebuild, couldn't hurt to put this setup in. Not really breaking the bank pricewise.
Josh
Diesel Cub Cadets...........
Old 01-21-2015, 01:41 PM
Well worth the $15 or so, IMO. I can tell less drag on my 129 steering after adding the bearing.
Old 01-21-2015, 03:55 PM
a3v03v0's Avatar
a3v03v0 a3v03v0 is offline
The forum's technical library has a good article on rebuilding the box. Getting the box right it important.
The kit replaces a single washer with a thrust bearing sandwiched between two washer. Instead of surfaces rubbing together you have balls rolling in races. Less friction. Just like the others said
Old 01-21-2015, 07:45 PM
I figured it was something like that.. Thanks,, just one of them things you don't know unless you ask!
