Think I'll check this out
-Ryan
I hope you're kidding or really know what you're doing. Ether can make scrap out of an engine QUICK!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
I want a can just to sit on the shelf
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
I don't like using that stuff. I have but very very sparingly! Only cub I used it on was when my engine me was worn out and wouldn't start. When it wouldn't I knew it was time for a overhaul! Be careful with that stuff!! Easy to blow an engine!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
I expect he is. When I have something that don't start I prime it using gas mixed for 2 cycle. The oil in it helps lube the cylinder during startup.
![]() Quote:
-Ryan
It's for engines going "DOWN UNDER".
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
"Start or Blow UP"
![]() Quote:
Saw the shop foreman blow the plastic valve covers off a 3.8 ford Taurus years ago. They hit the roof of the shop 14 or 16 foot high. Engine had jumped time and would almost catch, so out came the starting fluid. Boom!! I was working on a car in the next bay and couldn't stop laughing.
