Old 04-01-2010, 10:06 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
Default Newbie question
I was wondering, before I break down and order one, if I were to get a Cat 0 3 pt., will I be able to hook my 1A tiller up to it? I realize that I would need a longer belt from the gearbox to the tiller, that isn't a problem.
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 04-01-2010, 10:35 PM
redwaycc's Avatar
redwaycc redwaycc is offline
no. the tiller attaches to the gearbox frame and uses the tractor's lift to raise and lower the tiller. you can attach the 2nd and 3rd pt of the "3 pt" to the tiller gear box frame and then attach a sleeve hitch to that.
there is some usefull information in the tech lib.
http://ccmanuals.info/pdf/1A%20Tiller.pdf
100(2) 128, 129, 76(1/2)
Old 04-01-2010, 10:39 PM
I guess redwaycc has never seen the Cat-0 adapter package for the tillers.
I started reverse engineering the kit. See this thread:
http://www.onlycubcadets.net/forum/s...ead.php?t=3472
Old 04-01-2010, 11:15 PM
redwaycc's Avatar
no Matt G. i have not seen one nor have i see one for sale either. will you post that link too?
Old 04-01-2010, 11:21 PM
Is that the 3pt from Xtreme Motorworks?
Old 04-01-2010, 11:49 PM
I have seen a total of two for sale in the past 7 years. One was on a 782 at an auction (should have bought it, but I was only 15 at the time and didn't have the money...), and the other was for sale on another forum roughly a year ago, so no link. They are not common. The setup is briefly mentioned in "Cub Cadet: The First 45 Years" by Hank Will.
bridgewatertek-
No, it is the OEM 3-point (the xtrememotorworks version is a copy) mounted on my 782D. The really nice thing about this is that the gearbox can be installed or removed in a couple of minutes. I still have to find the right length belt and make the linkage that connects the 3-point rockshaft to the tiller to lift it.
Old 04-02-2010, 12:08 AM
Might I add that this is for my 1450, which didn't come with an OEM Cat 0. What I am thinking is bolt the gearbox directly to the 3pt and use the 3pt to raise and lower the tiller instead of the rockshaft. The main thing I am wondering is if you guru's think it would be plausible?
Old 04-02-2010, 12:23 AM
So my my best bet if I wanted to add the 3pt from Xtreme would be to bolt the tiller frame and gearbox assembly to the 3pt back plate?
Old 04-02-2010, 09:16 AM
You'll actually need to come up with something like I did, or find one of those kits. Notice how far down the gearbox is mounted on mine. There will be nothing to bolt it to if you try to bolt it directly to the plate.
