Old 01-25-2015, 06:38 PM
tobo127 tobo127 is offline
Default Mechanical PTO question
How common is it to change the triangular spring on the PTO. When rebuilding/cleaning the PTO does everybody reuse their spring or change to a new one if given the chance (do they typically lose tension)? I've seen posts where some have used two springs for added holding power, is this common/recommended? At this point I will be using the unit for mowing (42" deck) and tilling (model 1) with one extension. Will be changing the bearing, thrust button and wear button, friction disc looks good. Direction and/or comments?
Old 01-25-2015, 07:23 PM
The "B" and "B" with brake PTOs came with two springs.
When you buy a new "rebuild kit" for a "B" or "B" type with brake the kit comes with two springs (and both should be used).
With the same style PTOs I have read where some used two disks although I don't remember ever seeing one in person.
Springs for these type PTOs can be purchased separately.
The "A" style PTO used only one spring, and because of the way it is made, I don't believe that two (springs) could be used.
It has been my experience that if the "A" springs get hot, they no longer "spring" and are useless. The "B" springs seem to be some better with regards to getting hot.
Oddly enough, I have never seen an "A" type springs available without buying a "kit".
If anyone knows if the "A" type springs are available I would greatly appreciate a heads up.
Old 01-25-2015, 07:51 PM
No springs for the A type for sale,only in a kit like you say,but here is a pic of one with the 2 discs
