Old 01-28-2015, 07:57 AM
Bearklr Bearklr is offline
Default 1810 rear
One other question I have is regarding the rear in our Cub Cadet. I didn't get to look at it yet but I have heard my uncles say about "how solid it is" and "they don't make them like that anymore". So I tried to do some digging to figure out what they meant and I saw that when IH manufactured them they used a cast iron rear. However, I also saw that when MTD took over they switched to aluminum but I wasn't sure when. I was hoping someone could point me in the right direction on how to find out. I would say the tractor was purchased new around 1987.
Old 01-28-2015, 08:12 AM
IH sold the Cub Cadet division in Mid 1980. They sold to Cub Cadet Corporation (CCC) a division of MTD. MTD used the IH design and production parts for a while. Starting at S/N: 720,000 and greater (in mid 1983) they started using an Aluminum Rear end. I am assuming, this was done as a "cost savings" plan.
Old 01-28-2015, 08:38 AM
You have an aluminum rear in your machine. There is nothing wrong with the aluminum rears and they actually have better internal parts. There are 6 bolts that attach it to the frame. Use a torque wrench and check your bolts at least once a year. The bolts working loose is the only issue with them. Let's see some pics of your machine.
Old 01-28-2015, 10:36 AM
Will get pics this week! Just getting ready for paint and new decals. Motor has been disassembled, serviced and compression tested, carb rebuilt, all electricals gone over and serviced, belts checked and fuel system cleaned. Runs like a top and now it's time to make her look pretty again!
Old 01-28-2015, 10:48 AM
Disassembling an engine for "service" seems like overkill..... I usually service mine while they are assembled....
Old 01-28-2015, 02:10 PM
We actually took it to the local cub cadet dealer as we thought we were having compression issues in one of the cylinders. They took it apart to check the cylinders and make sure everything was on the up and up. Runs like a champ now.
