Just curious if any of you guys have ever seen a sleeve hitch ball. I got one from a gentleman a few years back. It is an inch and 7/8. It fits in the hole where you would hook up your brinly plow. I'm asking if anyone makes one of these in a 2" ball? I'd love to have one of each.
Jeff in Pa makes a thing that the ball bolts to and you just pin it on your adapter. Xtreme also makes the same thing. Pics are from Xtreme's web site.
I use a simple yoke with a CC draw bar bolted to it and a trailer ball in the draw bar that attach to sleeve hitch adapters. I have one with a 2" ball and one with just a draw bar. I"ll look for a picture.
Edit: Yes, like the pictures that Sam posted, except the draw bar bolts to the yoke rather than having the piece welded to it... Either way they work well.
check out this brain storming thread about various ball mounts..........
http://www.onlycubcadets.net/forum/s...ad.php?t=30667 |
The ball I'm referring to has a long neck on it. It goes in the brinly adaptor piece or "U" shaped piece. No other bracket is required. I'll try and post a pic later.
The ball goes in the same hole that the pin goes into
Yep I get that. Look for one of those balls that use a carriage bolt in the center.
If the bolt on the ball is narrow enough of a diameter you can just mount it directly to the triangular shaped hitch. We did that for years with dad's 125 and an IH carriage bolt centered ball.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Might have to visit your flea market for a used one. |
![]() I'm getting ready to make one for a forum member tomorrow. I have material for more if you order. $35 plus shipping |
