Old 02-01-2015, 07:31 PM
RedHawCadet RedHawCadet is offline
Default Push blade
I just picked this blade up off c-list, a 3 hour round trip drive, and a 110 dollar speeding ticket later. Now its home and would fit in the qd. Am I missing something? Thanks in advance.
Mark
1971 Model 73 - Hydraulic lift,Fenders,Creeper,Lights,Sleeve hitch and Weights
1967 Model 102- mower
1965 model 70 - weights,rear lift and spring assist
Model 100 resto mod project, rear PTO, hydraulic lift
QA42 snow thrower
42in front blade
Grandpa's F-12 and Super M
Old 02-01-2015, 07:41 PM
Do you mean wouldn't fit?
That is because it is not correct for a QA. Looks like one for a 70- 123.
Up to 534 and counting...
Old 02-01-2015, 07:59 PM
Shouldnt it still bolt on?
Mark
QA42 snow thrower
42in front blade
Old 02-01-2015, 08:02 PM
Here's dimensions from my bolt on blade I use on my NF 125
Old 02-01-2015, 08:34 PM
Do you have pics of the other end that goes on the footrest rockshaft?
Old 02-01-2015, 08:40 PM
Do you happen to know the I.d of the two tabs that slide over the frame? 11"..........
Mark
QA42 snow thrower
42in front blade
Old 02-01-2015, 08:49 PM
For some reason the picture in my photobucket has 10-7/8" between the ears but this pic doesn't
The hole in the tabs in for a 1/2" bolt.
Old 02-01-2015, 09:03 PM
Well I'm wondering if its bent, 1/4 off side to side wouldn't be real visible and would make a big difference. My QA42 mount measures 11". This is under that.
Mark
QA42 snow thrower
42in front blade
Old 02-01-2015, 09:07 PM
My QA42 mount has to be squeezed in with the bolts and the blade is close.
Do you have 7-1/2" from the top of the bar to the centerline of the mounting hole?
Old 02-01-2015, 09:15 PM
I measured 7" and the length of the carriage is 31 3/8's
Mark
QA42 snow thrower
42in front blade
