I was wondering if anyone has done this. I have the chance to buy NOS Kohler Magnum 18 I wonder if it would bolt in place of a KT17s I guess it would all come down to crankshaft size and diameter
All depends on how the Mag is spec'd. If it has the same PTO size then it should play, and even at that you may be able to work around the differences. Some wiring differences will need to be dealt with but no big deal.
As Sam says if the pto shaft is 1-1/8" and length is enough it is almost a plug and play, many of us have done it.
The M-18 is the best of the flathead twins. |
Hello, if it has a 1" shaft get a pto from a briggs that was in a 582, will bolt right up. BTDT Mike
IF.........you are doing a Cub Cadet spec'd engine swap, it is s drop in replacement. The only thing that will have to be done is a minor wiring change.
