Old 02-03-2015, 06:43 PM
blee128 blee128 is offline
Default Port and polish
Been thinking about porting and polishing but would would like to try it myself any help as to where to start or if I just need to let somebody else do it or is it even worth it thanks!!!
Old 02-03-2015, 06:56 PM
austin8214's Avatar
Whether or not it's worth it depends largely on the cam you plan to use and how many RPM you are planning to turn.
Old 02-03-2015, 07:33 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
stock ports will outflow stock valves and seats,
Old 02-03-2015, 08:43 PM
Ok that's what I'm looking for I have a 321 with the small exhaust valve so I'm gonna make it an 1-3/8 anyway so that would probably be the better thing to correct?
Old 02-03-2015, 09:29 PM
austin8214's Avatar
I don't believe it's worth putting in a lager exhaust valve in.
Old 02-04-2015, 08:14 AM
dvogtvpe's Avatar
I'm with Austin
Old 02-04-2015, 08:20 AM
Ok thanks guys
