Old 02-11-2015, 03:17 PM
Tankman's Avatar
Tankman Tankman is offline
Default 1641 Deck Lift
Gettin' ahead of myself but, have a question.
Does the 1641 have single deck lift system? My 48" SD deck has two links to the lift.
Can you leave the deck on and lock it in the up position?
For towing wagons or a future 3-point lift kit.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 02-11-2015, 04:09 PM
Single lift.
Only way to lock it is with the deck height adjuster at the rear of the tractor but it should stay up providing that you don't have a leak down problem with the hydraulics.
If you put a 3 point on it both the deck and 3 point function off the same hydraulic cylinder so they both go up and down at the same time.
All of this is in that service manual that I sent you.
Old 02-11-2015, 05:20 PM
Tankman's Avatar
Danka! Guess I should read more.
The service manual is excellent, referenced very often. Missed this one.
Waitin' on the PTO, mowin' 'n towin' with the grandsons will pass the time. Quality time!
Just reinstalled the front bumper, new hardware and a paint job. Yuk rust! Not as bad as the poor Cub's yellow, but nicked up some.
Tankman
'95 CCC 1641
Eastern PA
USMC
