Old 04-04-2010, 09:04 AM
JeffD JeffD is offline
Default 129 sleeve hitch?
I just picked up a 129 yesterday, and would like to set the tractor up for a plow. It does not have a sleeve hitch, and I was wondering if any wide frame sleeve hitch would work? Or does it have to come from a 129, 149, 169 etc?
Thanks.
Jeff
Old 04-04-2010, 11:00 AM
transformer transformer is offline
I believe that a sleeve hitch from any cub narrow, wide frame, through the quiet line series will work....But you must have the 3 point for your tractor as well to work with the hitch....hope this helps....Randy
Old 04-04-2010, 11:42 AM
Sorry, that is what I meant to say was the 3 point. Will a 3 point from a 82 series work on the 129?
Thanks.
Jeff
Old 04-04-2010, 11:49 AM
Sorry cant answer that one...Ive never had a 82 series so never researched it.All I have are wide and narrow frames and the the three points are different for them depending on model #.Some of the other guys will chime in and let ya know..
Old 04-04-2010, 12:04 PM
The cast piece and lower bracket will, but the lift bar is completely different. I'd find the correct one, which should be much easier to find than 82 series ones are, anyway.
Old 04-04-2010, 12:23 PM
Here are the differences with the Lift Lever (Upper Casting). The 129 would have this on the rear end of the frame. Pay attention to the welded collars on the frame.
Starting in the mid Q/L series, this collar disappeared and just a hole was in the same spot.
The original lift system used a "shaft" that went through the collars and the Lift Lever. The Second Generation, did away with the shaft and went to the Stud Bolt design (aka: Frankenstein bolts). See image below.
The Lift Lever remained the same, but it depended what your frame setup was that determined whether you need a "shaft" or the "stud bolts"
The shaft, I believe is NLA from Cub Cadet but it is simply 1/2" in Diameter and the length would be just enough tp span the frame width.
Old 04-04-2010, 04:15 PM
Thanks Roland, That helps a ton!
Jeff
782 w/Honda power
129 stock for now...
100 basketcase
Old 04-05-2010, 08:32 PM
F7Hooligan's Avatar
F7Hooligan F7Hooligan is offline
I just purchased a 3 pt. hitch from Rich at Patton Acres for my 149. It has the shaft through the lift lever. I'm assuming I have to pull one of the rear wheels and install the shaft through the outer hole, is that correct?
Old 04-05-2010, 08:49 PM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
You are correct. That's what we had to do on our 128.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 04-05-2010, 11:22 PM
F7Hooligan's Avatar
Thanks Mike, that's what I thought but it's always better to ask someone who's been there and done that.
