I have a Brinly sleeve hitch that is missing the pins that attach it to the base plate. PO used bolts which are way too small. Anyone know who might carry them and what size are they? Mine came with one long pin and a shorter one. That I assume are used to attach the lifting straps to the lift pin and hitch.
Thanks.
CSXengr _______________________________ 124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart. |
I make a sleeve hitch adapter similar to the Brinly only more heavy duty. It uses 1/2" pins and 1/2-13NC bolts. The implement pin is 5/8"
Home depot, lowes or good hardware store carry them .Like Jeff said they are 1/2 inch diameter. They are called clevis pins. I use a 1/2 rod through both holes. Makes it more stable. Old broken tie rod shafts work good. Just cut to the length you need ans drill a hole at both ends. Or buy 1/2 rod.
Tractor Supply keeps them in stock back with all the hitch pins and stuff if you have one close by.
