Old 02-18-2015, 08:39 PM
pullin pullin is offline
Default K-301 in a model 126
I bought another model 126 today. So now I have two... How come on the engines that are both kohler 12hp. One of the oil dipstick goes into the top right front of the block and one of them goes into the left side of the engine?
Old 02-18-2015, 08:48 PM
the one with the dipstick on the left side isnt original, the left side dipstick is from a newer tractor.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-18-2015, 08:54 PM
Ok, will the crankshafts be the same do you know? The original engine is a k301. The other engines description tag is warn so I can't read it.
Old 02-18-2015, 08:57 PM
if there both k301 the cranks will be the same.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 02-18-2015, 09:18 PM
K241, 301, and 321 all use the same crankshaft.
Old 02-18-2015, 09:51 PM
austin8214's Avatar
You sure about this. I thought that the 241 used a shorter stroke crank. While the k301, 321 and 341 used a 3.250 stroke.
Also not to nit pick but there are subtle differences in the k301 when compared to the 321 or 341. The 301 cranks do not have full counter weights.
Old 02-18-2015, 10:00 PM
Yes, that is correct. My bad. 301, 321, and 341 are the same stroke crank.
I don't know about the counter weights.... If it's a pulling engine, it should be a balanced rotating assembly, so it could be corrected.
Old 02-19-2015, 07:03 PM
Being it's 12hp and your saying that it is newer. What models could I match it up with to find out what model it really is?
Old 02-19-2015, 07:13 PM
What model what is? The engine? It's a K301.....
Old 02-19-2015, 07:46 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
chance's are the motor with the side dipstick may have balance gears, that was one of the reasons they moved them from the top, the 301 crank has lighter balance weights
