Old 02-20-2015, 02:40 PM
Ikea6e Ikea6e is offline
Default 82 series metal on an 1864 (Metal-Clops)
Goal was to put 82 series sheet metal on a Cyclops while maintaining the tilt wheel, indicator lights, etc.
The Cyclops dash had to be narrowed to fit the 82 series hood. This was accomplished by cutting a 3/8 inch wedge from each side the upper part of the dash.
The side panels were split and spread to meet the lower edge of the metal hood.
Each side of the dash needed trimmed to allow the side panels to fit properly.
Right side of the tower was drilled and tapped for a 1/4-20 bolt to secure the panel.
Left side required a new bracket with a 1/4-20 stud and the panel trimmed to clear the hydraulic lift lines.
Additional metal was removed from each side panel to allow adequate cooling air for the engine.
Perforated metal from McMaster – Carr was used to fill in the gap on each side panel.
Perforated metal was attached by spot welding on the right side. Works fine if you plan to repaint anyway.
On the left side J B Weld was used. Works well, doesn't burn the paint. Took a lot of time as each segmented needed clamped and time to cure.
If I was to do it again I would use perforated aluminum. Cut out the wedge shaped split and additional cooling opening in one piece and J B Weld them in.
I hope this is useful to anyone considering a similar project.
I may due a re-paint one of these days, or put the plastic back on .
Old 02-20-2015, 07:34 PM
snoel's Avatar
snoel snoel is offline
Slick job.
Steve
Old 02-21-2015, 09:33 PM
fourinchdragslicks fourinchdragslicks is offline
Looks better than what I did. I cut the rolled edge off the back of the hood and the lip off the cyclops dash. I didn't even bother to make the side panels look like they were supposed to be on it. I just needed the tractor to look better than an open front end. (the plastic was in really bad shape) I like the split vent down the side of the panel.
Old 02-21-2015, 11:13 PM
bocephus1991's Avatar
You did a great job! Looks great!
Brian
Old 02-22-2015, 07:23 AM
Thanks guys. I had some surgery in December, so had time to sit around and try to think of a fairly simple way of doing this and retain the Cyclops goodies.
This made a good time consuming (light duty) Winter project as it took a lot of trial and error making templates etc.
Now if Winter would just go away...;-)
Old 06-10-2015, 04:18 PM
Metalclops finally got a Foot control.
Very similar to the one on my 1862. http://www.onlycubcadets.net/forum/s...ad.php?t=37406
Now if I could get off my butt and get some paint work done..... ??
Ike
Old 06-11-2015, 10:29 AM
CubDieselFan's Avatar
That looks great. I have a 1860 that needs that setup.
Old 06-11-2015, 09:56 PM
Foot pedal or the sheet metal?
Ike
Old 08-19-2015, 03:59 PM
Default Got some paint on Metalclops
Finally had a few days with low humidity, so I managed to squirt some paint on the modified 1710 sheet metal on the 1864 (Metalclops).
I used Valspar (5339-15-6PK) International Harvester White Tractor and Implement Spray Paint - 12 oz., (Pack of 6) From Amazon. Got 6 cans of White and one of Yellow for $42. I got the yellow because it got me above $35 for free shipping so basically it was free.
Old 08-19-2015, 06:31 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Looks great! Why didn't you paint the filled piece of the side panels? I don't think you would be able to tell that they were there if you had.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
