Got some issues with my 1810 and was hoping someone could point me in the right direction. It's a late 80s model and I'm having issues with the hydrostatic. It sat for a few years and when I went to use it it moved like 5 feet then stopped. The motor continued to run but no movement when pushing lever forward or reverse. The oil level was low and I filled it to the top and then went to use it again and same thing. I tried leaving it in gear to work any air out and still nothing. Any ideas?
Welcome to OCC.
My first thoughts are, to change the Hydro Fluid and Filter. I am thinking some junk got into the Filter and causing a restriction.
Good idea, how much oil does it take. The TSC in town sells cub cadet hydro oil for 15 bucks a qt. Any other alternative I can use in case that's not it. They didn't have any filters not even sure what will work.
Drain plug right on the bottom? |
^^^Agreed
I hope you mean you filled it to the full line and not "to the top" literally.... ![]()
Oh and Thank you. This use to be my dads tractor so it's staying with me for as long as I can keep it. Using it primarily for plowing snow and pulling small trailer around yard.
It will move a few feet when first starting but then stop. Does that after it sits, but will eventually do nothing. Lots of little bubbles in oil after this issue too. I will drain oil and replace filter. |
Filter part numbers are: Cub Cadet: 923-3014 Wix: 51410 Napa: 1410 |
8 Qts? the stuff is 15 bucks a qt at TSC. Any thing else I can use in its place.
![]() ![]() ![]() Don't start an oil debate! ![]() Tractor hydraulic/transmission fluid. TSC sells that too. Yes, Hy-Tran (the CC stuff) is expensive. |
I pulled the rear cover, drain plug, and filter off. Found some slush like crap in there. Oil was low before but not that low when I see where the dip stick sits. 2 things. Can I spray carb or brake cleaner in there to remove any gunk, and can I make a gasket with some liquid gasket crap or do I need to find a new one. |
