Old 02-26-2015, 09:47 AM
Ikea6e Ikea6e is offline
Default 451 Blower
Hi,
Has anyone found a cure for Wet snow piling up in front of the chute and eventually blocking it?
Thanks,
Ike
Old 02-26-2015, 09:53 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I sprayed the inside of my blower with this stuff in the fall. It did ok. Before my last round of blowing I sprayed everything down with PAM. I also added flaps to 2 of the impeller fins to tighten up the clearance between the housing.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-26-2015, 10:16 AM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
This will take care of that problem forever.
Old 02-26-2015, 10:21 AM
jimbob200521's Avatar
I used my 451 ONCE this year so far, and it was in wet, heavy, nasty snow. As long as I kept it fed good, it didn't clog. But once the snow tapered off or I'd stop and try to start again, it'd usually clog. I think it just needed more run time to "shine" itself up but I'm sure some PAM or something similar wouldn't hurt.
Shrew: I thought you posted pics when you added your impeller "extensions". Did you, or am I going crazy? I'd like to see what you did. Do you really think it helped? Maybe I'll have to do this to mine for next year because after this season, it has earned it's place in my shop with but one snow storm.
-Ryan
Old 02-26-2015, 10:39 AM
sbauerz28's Avatar
I don't have any trouble at all with my blower. Yes, it has been completely blasted and repainted but I have never had a clog in the 2 years I've been using it. I never plow anymore because I hate the piles of snow. I've used it on everything from a dusting of snow to drifts a foot over the blower and also that wet heavy crap that the plow truck leaves at the end of your driveway after a good storm.
Old 02-26-2015, 10:54 AM
Shrewcub's Avatar
Ryan, I don't think I did. For that, I apologize! I will document better when I give it the once-over this summer. I used the roll plastic that Sam told me about. Drilled a few holes and pop riveted them on. Last I looked they were still there, but custom molded to the housing now. It was a little noisy when I first fired it up.
I actually put a couple pieces of it under the skids on my 782 blade last night to keep them from digging into the gravel so bad. I'm tempted to try them out but we only got 1". Kind of a waste of gas.
Edit: This did not work out. After 200' the round skids cut holes in the plastic. I will make wider skis for next year. Worked great at first.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 02-27-2015, 09:09 AM
Thanks guys,
I'll try some of those ideas. Plus I think I need to check the engine rpm.
Ike
