Old 03-01-2015, 02:15 PM
fleetlines's Avatar
fleetlines fleetlines is offline
Default Johnson Loader 10 tc manual request
A couple weeks ago I got what I think is a Johnson "Workhorse" Loader model 10 TC and have looked for a manual for it since. There are no numbers or stickers I can read on it. I downloaded one copy from several places but a few pages are not legible on them all. It wants a little TLC but works ok. Anyone have a copy or know of one they can send?
The gratuitous pics:
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 03-01-2015, 08:59 PM
Just curious what you need a manual for? It's a loader..... basic knowledge of hydraulics, and levers and that's about all you need. Don't know that any parts are available for it, and I've never seen a service manual. You may be able to find an owners manual, but that will pretty much tell you how to mount it, tighten the belt, and where to put the oil.......
Old 03-01-2015, 10:28 PM
fleetlines's Avatar
I know just enough about hydraulics to get myself into trouble. I just don't know what I don't know. For instance at one time I didn't known about Hy-Tran for Cubs. I bought two gallons of the wrong fluid right off. Fortunately, thanks to this awesome site, I caught that mistake in time and still have that fluid on a shelf. I have one leaky cylinder so that needs a seal replaced and it will need fluid but I don't know when it is full and I've never rebuilt a cylinder. I don't know about it's filter or any required maintenance. Basic stuff for some I some I suppose but not for me. Eventually I'd like to disassemble it, paint the machine and loader. Maybe put it on the 72 (but I think I want to do the foot control). I'd prefer reading the instructions first. I'm not being smart with you. I just don't know this stuff and don't want to make any boneheaded assumptions. I was ready to put some weird hydraulic fluid in my Cub's butt once.
Old 03-01-2015, 11:38 PM
Well..... I understand I suppose. Just for the record, I don't run hy-tran in my cubs, but we won't get into that debate. (Point is, I'm not sure you really made a mistake. )
Anyway.... As long as the reservoir on the machine is relatively full, like as in: with all cylinders collapsed, you can take the cap off and see oil near the top, it's full. As far as the filter, the old one should have a number on it that you can match up. If not, you can have it matched by size. (A parts store can help you with that.) Cylinder rebuilding is not really very hard, but if you have a hydraulic shop nearby it helps. They should be able to get you the kit you need. Honestly, when a customer brings a cylinder to me to rebuild, it doesn't take that long unless it's just completely shot. Probably wouldn't really cost that much to just pay them to do it. (I rebuilt one the other day in less than an hour, if that helps you understand.) Someone may have some info tucked away out there..... but honestly I doubt it. Back in my dealership days, I never saw a service manual for any loader. Parts and owners manuals is all I saw. I'm sure they probably exist.... but not likely. Honestly, your best bet is to just ask any questions here. I'm sure we can answer them.
Old 03-02-2015, 02:39 PM
fleetlines's Avatar
Knowing it leaked and not knowing what is full had me very concerned. I didn't know if I would risk doing damage running it since I didn't know what full was. It's a decent leak but as long as I keep it topped off I can use it for snow till the weather breaks then take my time having it apart if needed. I also don't really want to use it without going over it first.
The filter is some sort of screen. It sounds like I'll just have to clean the screen as long as it's undamaged. I've checked out cylinders being rebuilt (youtube) and am quite confident I can change a seal if it's like what I saw. Not different than other stuff I've done.
This part of a manual is useful info for me. I don't know if it's a service or opperators manual. I'm hopeful I could find the whole thing.
This site is fantastic and you really seem to know a lot in this arena but I don't want to bother anyone with dumb questions either, expecially without doing what I can on my own first. I think you are right and I won't be able to find a manual for it. When I get into it I will be posting my questions. Thank you for your patience.
Old 03-02-2015, 05:28 PM
darryljs's Avatar
darryljs darryljs is offline
What hydro fluid do you use, if I may ask?
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 03-02-2015, 06:34 PM
303 Tractor hydraulic/trans fluid from O'Reilly's.
Old 03-02-2015, 06:37 PM
darryljs's Avatar
Thanks Jon
