Old 04-05-2010, 09:35 PM
ihnick's Avatar
ihnick ihnick is offline
Default getting a creeper out
How in the heck can I get the creeper out of that 122. I've got it loose but the drive haft is screwing things up. So how do I get the drive shaft off. Some of the pins don't look to go all the way through
Nick.
Old 04-05-2010, 09:44 PM
Drive out the spirol pin that holds the driveshaft onto the input shaft on the creeper. Then split the tractor, and then you can unbolt the creeper from the rear. I hope you haven't been beating on the pins after you loosened the creeper.
This is all in your service manual, BTW...
Old 04-05-2010, 10:37 PM
ihnick's Avatar
thanks matt. i'll have to check it out tomorow. i dont have any narrow frame service manuals yet.
Nick.
Old 04-06-2010, 08:24 AM
You can use almost the same procedure that's in a WF service manual. The steps are the same, it's just harder because there is no removable tunnel cover.
Old 04-06-2010, 12:25 PM
JeffD JeffD is offline
I can't help with the creeper, but are you going down to Iowa this weekend Nick? Bob and the boys are headed down Saturday morning.
Jeff
782 w/Honda power
129 stock for now...
100 basketcase
Old 04-06-2010, 08:51 PM
ihnick's Avatar
no i'm not. never heard about it. i dont have a tractor ready to plow with yet either
Nick.
