Anyone have a "trick" for cleaning overspray from the ID tags on decks, ect. that will not wreck them?
Jay N. Eau Claire, WI RED 82 Series... The BEST cure for Yellow fever!
id like to know also but can say this no acetone i made this mistake and whiped the id plate on a motor bare a few years back
Acetone works real good, and in some cases too good. I would try Lacquer Thinner in a test spot and see how that works.
lacquer thinner is just as bad as acetone . if the overspray is from a rattle can try wax and grease remover (eg ppg dx 330) put some on a rag and rub it on the overspray. if the over spray is from a catylized paint (eg if it was sprayed with a paint gun and used a hardener) nothing will take it off without destroying it.
When I used to work for Dana we put grease on the ID tags before the axles and transmissions were painted. We would then wipe away the paint and grease. Once wiped the ID tags would be perfect.
I use denatured alcohol to remove paint from prefinished woodwork. Ive never used it on a ID plate but maybe try it in a small spot and see how it works.
I used lacquer thinner, it was the only thing that would touch it. If you're careful and work quick it works fine, just be sure you remove it all before you walk away.
Red '84 Cub Cadet 782 50" Deck, 54" Power Angle Blade, QA42 Blower, #4 Cart, #2 Cart, 400 Rear Tiller, IH Rear Grader Blade, IH Rear Rake, IH CI Weights, Rear Suitcase Bracket, Sleeve Hitch, Front Hyd. |
What about trying some Fast Orange hand cleaner?
Soft scrub may work as well.
