Old 04-07-2010, 03:25 PM
garrettsdad garrettsdad is offline
Default 149 front blade lift trouble
my blade only lifts about 1 1/2 -2 " off the ground, is this normal? thanks chris
Old 04-07-2010, 03:41 PM
No, it isn't. It should lift at least about 4".
Old 04-07-2010, 03:56 PM
bridgewatertek's Avatar
bridgewatertek bridgewatertek is offline
You might want to make sure you have the correct lift rod.
Jim Bridgewater, KD0FJO Osage, IA
1976 IH Cub Cadet 1650, 44A rotary mower deck, 42" snow blade, QA42A snow thrower, rear blade, cab
Well, that's out of date. Current count is 2 LT1050's, a 76, 1 2284, 1 2130, 1 2135, 1020, and 10 1250- 1650's, with decks, blades, snow throwers, and a Brinly plow
Old 04-07-2010, 04:43 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Or make sure the Rock shaft pin isn't sheared off. That's what happened to my sons 149 and the removal of the pin was a bear...
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 04-07-2010, 06:16 PM
Default 149
Ya it doesn't have the rock pin installed, which I thought could be the problem. What should be the length of the lift rod, I'd like to check that also. Thanks Chris
