Old 03-18-2015, 01:37 PM
BrandonC BrandonC is offline
Default Snow Blade Identification
I've been looking for a blade for my 1650 for awhile and found this one for sale locally. The guy has no idea what it's supposed to fit and I have never seen a front blade up close. This one looks like a Cub blade to me but every one I have seen pictures of for the Quietline tractors has been white. Does anyone know what this one is supposed to fit? Thanks.
Old 03-18-2015, 01:54 PM
rocker582special's Avatar
rocker582special rocker582special is offline
That one will fit your 1650. The PO may have repainted it, no big deal.
Old 03-18-2015, 01:56 PM
Cool, thanks! These things arent easy to find in Tennessee.
Old 03-18-2015, 09:42 PM
red211's Avatar
red211 red211 is offline
You got that right, I stumbled into the one I just got and it is rusted through in a couple of spots. That one looks good, if you get it check out the poly cutting edge someone used. It is cheap from McMaster /carr. I am going to get one fo rmine and maybe sheet it too since Mine has a few pit holes. Snow didn't exactly fall off the rough rusted face. I am sure paint would help too.
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
Old 03-18-2015, 09:50 PM
Looks like a newer model cyclops blade.
Up to 530 and counting...
Old 03-20-2015, 05:26 AM
Tankman's Avatar
Tankman Tankman is offline
Looks like the one I recently put on my '95 1641. Works great.
I did have to lengthen the lift rod 2" to get the blade all the way down.
Also installed a lift bracket for the lift.
The blade you're looking at appears to be in A+ condition. Good luck!
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-20-2015, 12:09 PM
Supposedly it's never been mounted, never used. I'm going to get it tomorrow if all goes to plan.
Old 03-20-2015, 01:40 PM
SS5150's Avatar
SS5150 SS5150 is offline
Look like a tall axle Cyclops subframe
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
