Old 03-20-2015, 10:27 PM
gdheck's Avatar
gdheck gdheck is offline
Default Know where I can get a cat. 0 quick attach toplink?
Anyone know where I can find a quick attach toplink, or just the end, for a category 0 3-point? They look like the one below. They are more common on full size JD tractors. I've got a bunch of smaller branches to rake up with a landscape rake. I was thinking it would be really nice if I got a big ball in front of the rake, I could just reach back, unhook and let the rake pivot on the lower links kind of like a dump rake works.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 03-20-2015, 10:52 PM
john hall's Avatar
You trying to get it to float more? Never seen a quick center link on anything that small, just big Deere's (that's not to say its not made).
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-20-2015, 10:54 PM
They do not make one for Cat 0/1.
I don't understand how disconnecting the top link would allow the rake to "dump". It would still be touching the ground, just at a different angle.
Old 03-21-2015, 12:10 AM
gdheck's Avatar
The idea is to disconnect the top link and I can pull the top of the 3 point frame forward while I lift the 3 point and pull forward. This will be a rake like Xtreme Motorworks sells. See below. The rake is not extended behind the 3 point frame, which will be light enough to do this with.
Old 03-21-2015, 12:15 AM
I'm sorry.... I'm confused. It's attached to the 3pt. Wouldn't picking it up work too?
Old 03-21-2015, 01:22 AM
gdheck's Avatar
If I was just raking gravel or wanted to stop often and leave a bunch of little piles, it would work just fine. I have about 1-1/2 acres with a lot of trees and because of the surroundings, I can't burn like we do in the country. There's lots of limbs on the ground that I've pushed into piles to be loaded and hauled off. Now I'm left with a lot of small stuff under the grass to rake up. I want to go until the rake is completely full, dump it in one neat pile and rake more. The way the rake is built the 3 point doesn't have enough lift left to raise the rake high enough to clear the pile and I didn't want to rework the rake. The idea was to get the extra lift by disconnecting the top link and swing the rake up, but the purpose is defeated if I can't get a quick attach top link.
Old 03-21-2015, 09:42 AM
Berwil's Avatar
Berwil Berwil is offline
Why not use a chain with a hook on the end instead of the top link? Put the top link pin in the tractor and hang the hook on it.
Bill
Old 03-21-2015, 10:04 AM
gt383mag's Avatar
gt383mag gt383mag is offline
if you had a hydraulic remote back there you could use a small cylinder as your top link and dump it that way
Old 03-21-2015, 01:09 PM
Mount the top link in the lowest hole on the tractor, then shorten the link some. It will lift it high enough.
Old 03-21-2015, 09:12 PM
gdheck's Avatar
I had plenty of time waiting for a grain trailer to sell today to think about this. I think I'm going to go with Jonathan's idea, but if I still have problems, I'll just make an extra short link.
I may still try to do a qa top link just because I like to be lazy when I can.
