Old 04-08-2010, 06:36 PM
feathersg feathersg is offline
Default Any non OEM replacement for front wheels? - 1250
My 1250 I bought has newer wheels on the front that don't have bearings. Has anyone used a non-OEM wheel on a cub? If so, what?
The ID is larger than the shaft and I considered using brass bushings to make up the difference. With a thrust bearing on the inside and grease I am hoping this will suffice. Any thoughts or past experience? If I could get some OEM wheels I wouldn't have this problem.
Old 04-08-2010, 06:47 PM
Put a want ad in the classifieds. I'm sure a bunch of people have extra wheels.
Old 04-08-2010, 07:17 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
What size spindles does it have? 1 inch or 3/4 inch? That will also be something you need to specify..
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 04-09-2010, 07:01 AM
Here is the data from the Parts Manual. These are the only wheel rims used on the Quietlines....
.75" Spindles
IH 386188-R2 4.00" Rim NLA
IH 546730-R2 6.50" Rim NLA
IH 384881-R94 Bearing Avail
1.00" Spindles
734-3053 6.50" Rim Avail
941-3002 Bearing Avail
Old 05-14-2010, 08:35 AM
I now have some 3/4" shaft wheels from Patton Acres. What is the bearing replacement for a IH 384881-R94 in SKF,Timken, or Peer?
