Old 03-24-2015, 02:14 PM
raytasch raytasch is offline
Default Setup Instructions, Haban to a 2186, Do They Exist?
I have the sixty inch Haben deck ready to reinstall on my 2182. Search has not turned up any instructions so I ask of the experts. Sam Mack identified my deck as an early version and serial number dates the 2182 as a later version. I am not convinced the deck was ever properly installed, set up correctly.
The two collars shown were installed on the rear brake shaft that runs between the frame vertical sides. Each collar was beside the rearmost tab of the mower lift functioning as a centering device. The deck has the large frame mounted centering device. Are those collars shown actually a centering device or are they a sacrificial wear item that works under the rear tab of the lift frame? Are the sides of the lifting frame supposed to hit and wear on the brake shaft?
So much rambling, don't know if I made any sense or not
I don't know where the 2186 came from. Unit is a 2182.
122 original, well used. Owned since 1972
2182 new to me. Refurbished and gave to my son.
Deere 4300 4WDA HST with FEL
Many old Ford tractors, all gone now
Couple old Ford trucks
Old 03-24-2015, 06:01 PM
PM and email sent.
Old 03-24-2015, 06:45 PM
PM and email sent.
Received. Thank you, Jonathan.
Old 03-24-2015, 08:19 PM
I guess this is what the man sent you...Then enter 190-374-100
http://manuals.mtdproducts.com/mtd/P...randCode=10051
Up to 530 and counting...
