Old 03-25-2015, 08:06 PM
JLM78 JLM78 is offline
Default How do you guys put the Retainer in the rear end on ?
How do you guys put the retainer /number 11 on ?
Old 03-25-2015, 08:23 PM
cub123's Avatar
cub123 cub123 is offline
When I did it I put a 4x4 up the back of the case against the pinion and set it verticality on the floor, then you can easily pop the clip on.
Old 03-25-2015, 08:27 PM
I use a pair of pliers that look like snap ring pliers but with flat jaws that expand the ring, slip it over the shaft and done, you just need the proper tool to do the job, they look like this.
Old 03-26-2015, 11:19 AM
Thanks I have to get A set
