Old 03-26-2015, 02:12 PM
Group_44's Avatar
Group_44 Group_44 is offline
Default Xtreme Hub Adaptors
http://www.xtrememotorworks.com/Part...20Featured.htm
Anybody try these hub adaptors from Xtreme yet? (XMW PN# CC-52-011) I am looking at the 4 on 4 adaptors for the 1" axle. I have a load of 4 on 4 golf cart rims and tires that are the same size tire on the Supers. In the past I have always found Xtreme stuff well made. These adaptors look like they may be modified trailer hubs.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 03-26-2015, 02:44 PM
chris hall's Avatar
chris hall chris hall is offline
I just bought the 3/4 hub version. I really like mine so far.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 03-26-2015, 02:59 PM
Group_44's Avatar
What model tractor and what size wheels are you using? Did it change the stance of the tractor? Was curious about the quality of the bearings they use, I use the tractor with a heavy 450 blower.
1641 w/48" Deck
Old 03-26-2015, 03:30 PM
Other than going to a bolt on rim, I see no advantage whatsoever. Still using the same style of bearing as the original hub. Still a 1" axle. Not going to carry the blower any better than the original wheels, other than they might be a little bigger diameter.
Old 03-26-2015, 03:31 PM
Aaron sent me some pics of the 5 lug version a while ago. They look pretty stout to me.
Old 03-26-2015, 04:58 PM
Tankman's Avatar
Tankman Tankman is offline
I've been toying with the idea myself. If you have the rims and tires, why not?
Didn't know of xtreme until I picked up my 1st Cub, a CCC 1641.
http://www.mfgsupply.com/gomini/gominihubs/100h-w1.html
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 03-26-2015, 07:41 PM
chris hall's Avatar
124. .I am using narrow 5x4.5 wheels and 400x8 tri rib tires.All of Aaron's products are quality. I just like the looks of the 5 lug front wheels.
Old 03-26-2015, 08:23 PM
TIMCRUTCHER TIMCRUTCHER is offline
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 03-27-2015, 05:43 PM
Group_44's Avatar
Well, I bit the bullet and ordered a set of hubs from Xtreme today, I will see how they work out. I wasn't questioning if they would carry more weight than the stock hubs, I just was asking if the bearings were at least as good as the OEM items. I am counting on the fact that Xtreme has always turned out a quality product. I also will check to see how close the these are to the aftermarket trailer hubs and if they will hold the flange style bearing used in the factory hubs.
1641 w/48" Deck
Old 03-27-2015, 08:48 PM
V30crewcab V30crewcab is offline
I believe they use the stock cub wheel bearings. not sure how they could be stronger, I guess they might not bend like a stock rim could.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
