Seems as if the idler arm tension spring has lost some sprung?
Or, perhaps just a new belt'll do the trick? The tension / idler arm, jumps in my opinion just a bit much. This deck sat outdoors for 'bout a year. Belt looks good and I loaded it with CRC belt conditioner. Deck is in excellent condition after lots of wo....wo....work. Is it possible the belt length grew while unused outdoors; snow, ice, rain, sun, dark nights, gloomy days? A ride to TSC, Huskee Kevlar belt(s), seems to be in order. I find it obsene that one would leave a piece of equipment outdoors regardless. This Cub has a place, forever, in my barn. Poor Cubbie suffered enough! ![]()
Tankman '95 CCC 1641 Eastern PA USMC |
Put a new belt on it and clean the rust out of the pulley grooves.
Those idler arms have been known to freeze up on the pivot and won't move if left to the elements. There's no grease fitting so you have to take it apart, clean it, lube and put it back together.
All cleaned up and a new belt, Huskee Kevlar 1/2" x 107". I did grease again and the idler arm does have a grease fitting. 48" SD deck (Model #317).
Working so far now if the grass'll just get over winter. None of us like this cold, wet, white stuff. Grandsons love plowing, I'de rather smell freshly mowed grass.
