So i finally got my Block clean rust free and painted and ready to be put back together with new piston, rings all new gaskets, ect. I have been doing a little research on here and i just want to ask this before i get it wrong. Should I or should i not reinstall the Balance Gears???
leave them out
Most ppl are told to leave them out because when they go bad they tend to put a big fat window in the block, nobody wants that.
That said, some ppl replace the needle bearings/shafts that are worn and don't intend to run them over recommended rpm's, so they would be safe to use them. A lot of ppl can't tell the difference with them in or out, others do see a difference but most agree it is not a big difference. and IIRR the 16 hp don't come with them. So it is your call. You can't go wrong leaving them out, as no window effect will present itself.
After I am finished with this restoration project i highly doubt ill be doing anything heavy with this tractor mainly just for shows. But if there is not much difference with or without them i think im just going to go ahead and leave them out. Thank you both for your help.
I would leave them out. All they are is a hand grenade waiting to explode. I took them out of my k321.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
The first thing I do, when tearing down a K-series that has grenade gears is throw them in the scrap bucket.
Don B, USAF 1962-1968, Ft. Wayne, IN |
