Old 03-31-2015, 08:02 AM
SS5150's Avatar
SS5150 SS5150 is offline
Default 1861 engine coupler
Hey all I want to pull the mag 18 from my 1861 to give it a much needed bath, I see a cv at the back of the engine with 4 Allen screws, do I remove those to separate it? I'd like to get going on it soon, going to need it to mow here shortly. Thanks
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 03-31-2015, 08:12 AM
The shaft should just slip out of the CV joint at the engine end, it has a snap ring on the tranny end. Once you get it out it would be a good idea to disassemble it and clean the old hardened grease out and put some new grease in it. Drive shaft should have grease fittings on each end.
Old 03-31-2015, 01:12 PM
SS5150's Avatar
Thanks Sam I saw the fitting but couldn't tell how it separated. It must be splined inside the coupler then? I noticed the boot was not a tight fit to the shaft but there wasn't any kind of fastener there for it either.
RUN IN THE RED
1872 project
Old 03-31-2015, 03:32 PM
If the boot isn't torn put a zip tie on it when you put it back together.
Old 03-31-2015, 06:18 PM
Yep! Just did one today!
