Old 04-02-2015, 08:29 PM
yeeter yeeter is offline
Default Quick hydro seal change
Some pics on the hydro seal changes. One of them the new seal is all molded, where as the original one had a stamped steel structure. It didnt seem as good of quality, but at the same time it will likely work just fine. Once installed it gets a washer over the top of it anyway so functionally should be fine.
Did the trick of drilling a small hole through the old seal to then pry it out using pliers. Worked well.
Old 04-02-2015, 08:30 PM
Then back together
Old 04-03-2015, 07:00 AM
Nice work yeeter
Old 04-03-2015, 07:08 AM
cubs-n-bxrs's Avatar
Nice job yeeter. She ought to be good to go for another 25-30 yrs.
Old 04-03-2015, 08:08 AM
What they said. I see that you didn't replace the PITA one on the other side of the trunion.
Old 04-03-2015, 10:28 AM
I did consider it. Jmech talked me out of it, and I always do as jmech advises....
Old 04-03-2015, 11:07 AM
TheSaturnV's Avatar
Beauty eh! Good job not painting the Hydro fins.
Old 04-03-2015, 11:33 AM
LOL!
Nice work!!
Make sure to clean the paint off where the filter mounts. I can't tell from the pic if it's paint on tape, or if it's on the metal.... just make sure there is none before mounting the filter.
