I'm looking to put front remote on my bros 1863. I have the valve and stack adapter. How do I look up on partstree the layout and part numbers for it? Is there a model number or something ?
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
AFAIK, there were no models that came with it as "standard" equipment. It was an option on all models that had hydraulic lift, but it turns out to be not that common.
As for more how-to info beyond that, others will be along shortly to help out. From what I've read (as I will be doing this this year to my 1864 as well), you "simply" stack the valves with adapter and appropriate o-rings, get your hoses, route them, and violla. Hoses will be the hard part, though; they aren't standard thread. You can either find someone selling the remote hoses on ebay and buy them or open up the valve and tap it to standard threading, then go to your Napa or wherever and have hoses made. That's about all the detail I can get into right now at work. I'm heading out the door but that should give you a pretty good idea what you're in for ![]()
-Ryan
Not sure if they came from the factory, pretty sure it was a dealer installed kit. It shows in the service manual. I can e-mail you a copy if you PM me with your e-mail address.
If you have the valve and adapter it's easy. Just stack the valve. Cut the dash and you've got it. Doing this on a cyclops seems way easier than an 82 series. I am going to put a remote on my 2284 for a grapple. I would then just have napa make up some lines and get the quick connects from farm and fleet.
