Old 04-04-2015, 01:16 PM
RV-ERR RV-ERR is offline
Default Electric lift
I need advice on my I47 lift. I took it apart, cleaned it up, replaced the gears, lubed everything, put it back together and to my surprise it didn't work. I took the motor off repositioned, the brake springs, put it back together, same results. I took motor off again removed brake springs it works great. What am I doing wrong???? Are the brake springs really necessary Thanks in advance!!!! Curt
Old 04-04-2015, 01:22 PM
It would be easier if we had some pictures. So......did you install the Brake Springs correctly...??
Old 04-05-2015, 11:09 AM
Nightow1 Nightow1 is offline
That was my first question. I would go back and step by step check it. I just did a restoration on one and you have to make sure the Brake Springs are set correctly.
Old 04-06-2015, 10:42 AM
Default Electric--lift
Thanks for the reply guy's. NIGHTOWL since you have just done one looking at the pictures in the manual I can't tell if the brake springs go into the top groove or go to the bottom. my other question is are they necessary since it works with out them. CURT
Old 04-06-2015, 02:05 PM
i put the springs in over the cam and set them in the housing first then I dropped the coupling drive attached the motor in to the housing. If that makes any sense. I would use the springs they prevent the coupling from striping the cam.
Old 04-06-2015, 03:29 PM
TheSaturnV's Avatar
Under the category of "if it ain't broke," is there any reason to take mine apart and service it if it's currently working fine?
Old 04-06-2015, 03:32 PM
Not as far as I'm concerned.
Old 04-06-2015, 03:52 PM
I agree with J-Mech, The only reason I did it was because I want to sell it and I like to make sure it was in good working order. I would at the minimum grease it up and clean her. check wiring and such.
TheSaturnV's Avatar
Ok, wasn't sure if there were innards that run dry and get damaged without applying fresh grease every so often.
