Just making some final adjustments on the 1864 and I have one I cant figure out. When the brake is set, the hydro whines. If I release the brake and bump the hydro lever forward just a fuzz, it goes to the neutral position and stops whining. I have the fender pan off now and Id like to get this corrected before I put it back together. I know when you press the brake there is a mechanism that sends the hydro to neutral. I assume that's what I need t adjust but I don't know what to do with it and I cant seem to find it in the manual. Probably because I don't know what the adjustment is called.
1994 Cub Cadet 1864 1997 Cub Cadet 2165 |
Found a service bulletin on a cam pivot adjustment. Is that what I need?
Check out this video. This is what you need to do. Also check for worn linkage.
https://www.youtube.com/watch?v=phz_VqTZFRI Good luck. Ike |
That was it. No more whine. Thanks!
I think the PO never did anything but put gas in this thing. Everything that can be adjusted has needed adjustment. Manual says the toe on the front tires should be about 1/8". Im reading about 1". Thats all I have left to adjust and she'll be a grass killing beast!
You know what, that is really frustrating. I don't know whether the PDF files are missing info, or if the original manuals are. It is called "Cam bracket adjustment" and I had to go all the way back to the QL/wideframe service manual to find it. The '82 series PDF didn't have it and neither did the next series. I gave up looking before I went to the SM for the 1864. If the video doesn't help you, you can use the old QL book. The procedure is the same for all the hydro tractors, no matter how new or old.
Thanks Jonathan. The video helped me and its all fixed now.
After I got frustrated and posted my question, I actually found it in the manual Sam sent me but its not in the adjustments section, its all the way in the back as a service bulletin to cure slow reverse speeds.
Sheesh.... like I said, after not being able to find it in the two books I looked through, I gave up and went older. I knew it was in those books.
![]() I may have just missed it too.... but found it right away in the older book! ![]() I was going to get you a page number...... but you got it. Good deal!
