Old 04-05-2015, 06:33 PM
johns cubs's Avatar
johns cubs johns cubs is offline
Default 104
I have a 104 i upgraded to 12hp that i got from a buddy, and got it running good but noticed other day that the front pully is lose. Do i have to pull pto clutch to tighten? And did the 104 come with hydro lift? I also have a 105 hydro drive with hydro lift and plow but am considering installing pump and blade on 104 and possibly selling 105 with snow blower and mower deck. Any info is helpfull and appreciated thanks.
John.
Old 04-05-2015, 06:37 PM
What pulley are you referring to? Starter generator pulley? Also hydraulic lift was an option and can be transferred to the 104. Some already had holes in te frame and some not
Old 04-05-2015, 07:26 PM
johns cubs's Avatar
Drive pulley for pto. Just swapped engine couple weeks ago but needed to use tractor so i was not able to take my time and go over every thing. Wondering bout hydro because i dont care for the hydro drive on 105. Pain to plow with. And have 3ph arm on 105 i want to switch, looking at building single bottom plow. Tires loaded with chains but no weights yet...
John
Old 04-05-2015, 07:40 PM
johns cubs's Avatar
PTO pulley. Should have checked it all over when i swapped engines but was in need of tractor to get my firewood in before snow storm.
John
Old 04-05-2015, 07:46 PM
Originally Posted by johns cubs View Post
........ Do i have to pull pto clutch to tighten? ............ Any info is helpfull and appreciated thanks.
John.
There are two round cutouts / access holes in the back of the PTO basket on the pulley. I think you might be able to get a long hex wrench into the set screws without disassembling it.
Old 04-05-2015, 11:34 PM
johns cubs's Avatar
Thanks Jeff! Would have been much easier off tractor if i wasnt so impatient!! where in pa you located? I am just north of binghamton ny. We got bout inch of snow today. Thanks for the info! I do appreciate it! I have a 10hp that came off it with broken rod any ideas on parts?
John
Old 04-06-2015, 08:18 PM
About 15 miles south of Allentown
Old 04-06-2015, 10:31 PM
johns cubs's Avatar
Finally get my 105 back home tomorrow!! Gonna start stripping the hydro pump and 3ph and some other stuff i got to transfer to the 104. Gotta switch hoods back around. Guy i got them from had both tore apart and miss-matched stuff when putting back together, not huge deal to most people(him) but i like to have the hoods match the tractor. I do not have the wiring harness for lights for some reason but 105 has the bulb mounts in it. What do i hook lights up to? So they come on with key? Will have pics tomorrow as long as its not raining too hard.
John
Old 04-06-2015, 10:49 PM
The lights on the 104/5 should have it's own switch. They are not meant to be hooked to the key.
The OEM switch was mounted to the tower just below the dash on the LH side of the tractor.
Old 04-07-2015, 01:11 AM
johns cubs's Avatar
I have not seen a switch, or a place to put one on either tractor. Only a spot for lighter on dash in right hand top corner. Can some one post a pic where it belongs. And where would i look for a set of 3pth arms? Any body have pic of them and possibly measurements? I may fab a pair. Thanks for any help!
John
