Old 04-06-2015, 11:06 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Default 100 w/Ag 8.5's" & 38" 3-spindle deck
Ran into a figment issue trying to put a 38" 3-spindle deck on my 100 that wears a set of 8.5" Tru-Powers on the back. For some reason the tires don't fit between the gauge wheel ears on the deck. I am using the subframe that came with the deck in the picture, which came from my parents' 100, though their tractor wears a set of 6-12 stock turfs on the rear.
Note: The stub axles only add approx. 1/4" to the width on each side.
Any suggestions on how to make it fit without cutting the ears off?
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 04-06-2015, 11:16 PM
I know it's not what you want to hear, but you can either go to 6-12s or a 42" deck.
Get 6x12 tires as the deck is not made for 8 50's but there was a kit to mount the gauge wheels between the inside of the tires like this one,or get a 42"deck
Old 04-06-2015, 11:36 PM
litlmikeyl's Avatar
I do have a 42" deck, a Part #2 ('68-71) version, though it's in a bazillion pieces. It's in the middle of a major rebuild.
Mike - Ramsey, MN
'65 100 - #126432
Old 04-07-2015, 07:35 AM
Ditto.............
Old 04-07-2015, 08:58 AM
Darrell Darrell is offline
You could get some wheels that would have an offset that would put the wheel/tire closer to the tractor .
I know that would be kind of a pain , different wheels/repaint/remount tires , just a thought !!
Old 04-07-2015, 09:37 AM
You could modify the under carriage a bit and move the deck forward, wouldn't be to hard.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-07-2015, 10:32 AM
just reverse the wheels,put the smaller offset outside...like a jd has
