Old 04-07-2015, 01:31 PM
OldCubby OldCubby is offline
Default How can I tell the difference?
So, I'm ordering new pulleys for the mule drive for the mower deck assembly...but I've seen a few sites state they are Stens. Does IH no longer make them and this is my only choice? I'm looking for longevity here. I don't want to keep replacing these pulleys.....whats everyones thoughts?
http://www.cubcadet.com/equipment/cubcadet/ih-61176-c92
http://www.mowpart.com/280-188-stens-v-idler.html
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 04-07-2015, 03:23 PM
The "stamped steel" or solid cast iron, are the ones you want. Stay away from any cast aluminum ones.
Old 04-07-2015, 05:34 PM
bocephus1991's Avatar
Well they say that their a direct replacement. Look like the ones I got from cub cadet. I don't know what they charge for shipping, don't think my dealer charged for shipping. I would get them.
Brian
Old 04-07-2015, 07:26 PM
# 261560444650 ebay
Don't know anything about these
Old 04-08-2015, 09:43 AM
I used Primeline #705482.
Old 04-08-2015, 11:29 AM
Wow, $6.35 for those Primeline at Mill Supply. I'm assuming you like them since you're suggesting them.
Old 04-08-2015, 11:36 AM
is it possible to take them apart, clean them, and put in new grease? Or are they all internal?
Old 04-08-2015, 11:38 AM
So far they are working well, only time will tell of course. I tilled my whole garden and they were still cool to the touch. They are catalogged as "heavy duty", I looked at several before using these, I couldn't justify the solid jobs that are around $50 each. They do not have replaceable bearings though.
Old 04-08-2015, 01:17 PM
ok, so I am having to get new belts as well for the mower. Both belts actually. So, I was looking up the parts on cubcadet.com and it classifies it by the different serial numbers on the mower itself. So, I looked at the serial number on the mower itself and its: 03200170110395
would the serial number happen to be 110395?
and its a 44A mower deck
Old 04-08-2015, 01:36 PM
KayakDon's Avatar
KayakDon KayakDon is offline
I've had great luck with these, and this seller. I don't know if these are the actual ones you need , but I bet he has them. Don
http://www.ebay.com/itm/Cub-Cadet-Id...item1c50d02204
If it can't be fixed with a hammer,then it's an electrical problem
