Old 04-08-2015, 09:51 PM
farmall bob farmall bob is offline
Default 1861 cat 0 help
hey guys i am trying to put a cat 0 on my 1861 but have a couple questions. first is the down stop adjust rod.there is no hole for it i was gonna drill one in the hitch plate but its going to hit the internal arm. does that rod have to be level or just move it up to clear. second the lift rod i have i am coming to conclusion i have is for a manual lift tractor.thanks bobby
Old 04-08-2015, 10:36 PM
Lift rod looks right to me....
I don't know about the height adjusting rod. I don't remember there being any reason you can't slightly change the mounting position for it. You really need a set of mounting instructions for that hitch. I'm assuming you bought it used? Do you know what it came off of?
Old 04-09-2015, 11:26 AM
red56turbo's Avatar
The lift rods for Cat O on manual lift tractors are different than the ones on a hydraulic lift tractor. The lift rod you have pictured is for a manual lift tractor.
Here's a pic of the manual lift versus hydraulic lift. First pic, manual lift. Second pic, hydraulic lift (pic from CC specialties).
Josh
Diesel Cub Cadets...........
Old 04-09-2015, 06:29 PM
ok thanks guys now to try and find a used lift rod
Old 04-09-2015, 06:47 PM
Aaron at xtrememotorworks.com sells them. Scroll down the page, you'll see them.
