Old 04-11-2015, 11:29 AM
Nightow1 Nightow1 is offline
Default Haban sub frame & mule drive problem.
Ok I have a complete carriage for my 2182, i bought another because the subframe was kinda messed up. So the one i just received is a little different. I was told by the dealer i bought it from its the correct one but i just dont know these darn mower decks. So the one that came with my 2182 has 5" front pulleys and the new one has 4" pulleys. The hangers are shorter. And the tube on the back side dosent have the hole through it. So im frigin lost. I sent the guy the sn ofd my deck and my tractor model. so did the PO have the wrong one or the one i just bought is right.
Old 04-11-2015, 03:00 PM
Post a pic of your deck.
Old 04-11-2015, 04:22 PM
Here are a few.
Old 04-11-2015, 04:52 PM
OK you have the early style Haban. It would have had the small pulleys on the mule drive. This is what the whole thing should look like.
Old 04-11-2015, 04:55 PM
Ok so the PO had the big 5" pulleys on they were wrong? It worked great when i used it. So I need to use the one with the 4". Thank you. I just cant seem to get my head around these decks and pulleys and frames lol.
Old 04-11-2015, 06:33 PM
If your 2182 has the 6" PTO then I would use the larger mule drive pulleys along with the larger driven pulley for the deck. I did the same thing on my 2182 with the older style deck.
Old 04-12-2015, 08:07 AM
I converted my older style Haban like the one you have to use the larger pulleys. I use the larger mule pulleys on both of my Habans. You can change the center driven pulley on the deck, the part number is 756-3057.
First 3 pics are of the older deck, mule drive and lift carriage last 3 pics are of the newer style setup.
Old 05-12-2017, 02:35 PM
Cub2182 Cub2182 is offline
Default 2182 w/ Haban 60" Deck and Mule Drive
Ok guy's
I am brand new here on the forum and looking for advice. My 2182 w/ 60" Haban deck has been giving me fits since last season. Eats the mule drive belts, burns them, flips them over etc... I have already tried different belt types and sizes but got nowhere. I just bought a new Mule Drive from Pattons for a 2182 w/ 60" Haban deck. Removed the old mule drive and found the new one has the larger pulley's installed. Someone mentioned that you can use it but other changes have to be made? How do i know what size pulley is on the electric clutch? Any advise would be greatly appreciated. I have went thru 8 belts since the end of last season lol
I attached some pictures
Old 05-12-2017, 04:01 PM
OK your 2182 is an early machine. It should have the small PTO that is correct for your deck. I'd put the new mule drive on with a new belt and unless you have other problems it should work.
Here is some reading for you.
2182 #1
http://www.onlycubcadets.net/forum/s...ad.php?t=27880
http://www.onlycubcadets.net/forum/s...t=21718&page=2
http://www.onlycubcadets.net/forum/s...ad.php?t=21261
http://www.onlycubcadets.net/forum/s...ad.php?t=15421
http://www.onlycubcadets.net/forum/s...ad.php?t=16072
2182 # 2
http://www.onlycubcadets.net/forum/s...ad.php?t=35311
Haban deck info
http://www.onlycubcadets.net/forum/s...ad.php?t=33020
http://www.onlycubcadets.net/forum/s...ad.php?t=29727
