Old 04-11-2015, 07:44 PM
Daniel1962's Avatar
Daniel1962 Daniel1962 is offline
Default 3 pin driver
Good evening folks,
I am nearing the point in my 1200 QL rebuild where I need a new 3 pin driver.
I have read several older post and it seems obvious that the stock driver is very flimsy. These things are selling for $120-$130 new and the used ones dont appear any better than mine. Before I bite the bullet & buy one, Is there anything I am missing that I can do or an alternative to make this any different? I think alot of you veteran members are very crafty when it comes to improvising.
thank you
Dave
1976 Cub Cadet 1200 & 44A mower
1964 Cub Cadet 100,
No Attachments at this time, I do have a cart to pull stuff around.
Old 04-11-2015, 07:52 PM
Post up pics of the driver. Maybe I can figure an inexpensive repair
Old 04-11-2015, 08:30 PM
jcsmith jcsmith is offline
Default clutch driver
Lakota has nice aluminum 3 pin stock replacement clutch drivers for $55.00.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 04-11-2015, 09:02 PM
the 3 pin driver on a ql is designed to flex since its a rubber mounted engine, if you put solid mounts in you can run a standard non flex driver thats much stronger and cheaper.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-11-2015, 09:51 PM
Daniel1962's Avatar
I had considered going with solid mounts, but I've already got new rubber one's
I'll post a picture tomorrow
Thanks
Dave
1964 Cub Cadet 100,
Old 04-11-2015, 09:55 PM
Well.... then you better shell out the $130 for a new one.
It would be cheaper to buy a set of solid motor mounts off Jeff and a used regular 3pin driver. Your choice.
Old 04-11-2015, 10:31 PM
Hand_108 Hand_108 is offline
Inactive Member
x2.... i converted my 1200 over to solid mounts, solid 3 pin. solid rag joint.
Old 04-12-2015, 08:46 AM
Bob95065 Bob95065 is offline
If you do go with a stock driver make sure you do the cradle mod to your engine mount brackets. The most likely reason yours broke is the ISO mounts failed and the engine sagged throwing the driveline out of alignment. If you do the cradle mod you will save your mounts and driver which will protect your investment.
Old 04-12-2015, 09:46 AM
Daniel1962's Avatar
Appreciate that info Bob, I did the engine mount mod, used the oil pan as a guide,
I'll go ahead and replace the driver with a new one and just hope for the Best.
thanks
Dave
1964 Cub Cadet 100,
Old 04-12-2015, 10:37 AM
thanks
Dave
I don't think you are hoping for the best. You fixed the problem.
The failed ISO mounts are probably the cause of the failed driver. If you did the cradle mod you killed two birds with one stone. You won't have a problem with ISO mounts or the driver again. Besides, the original driver lasted ~40 years before giving out. I think you will be fine for another 40+ years.
