Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 04-14-2015, 03:41 PM
Husker Husker is offline
Default Risk in boring a K321A?
I took my block in to the machine shop and was told it wouldn't be worth the cost to have it rebored, as they've seen a high rate of cracking. The guy seemed to knowledgeable, but I'm also concerned he doesn't want the hassle. He advised I just get a new block. 1. Do I tell him go ahead and bore it and accept the risk? 2. Any advice on where to get a replacement block? I emailed Cub Classics sponsor to see if he had any on hand, but haven't heard back yet.
Old 04-14-2015, 04:15 PM
Member Don Vogt would be the one to ask. BTW....you did NOT mention the size of the increased bore...!!!
Old 04-14-2015, 04:35 PM
Merk Merk is offline
I would find another machine shop providing it is only being bore up to .030 over. He doesn't want to mess small engines.
Project Uncle Dick
Cub Cadet 70
Old 04-14-2015, 05:41 PM
I agree with merk, it just sounds like an excuse to get out of doing it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 04-14-2015, 05:49 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
did the engine ever throw a rod? if it did you have to look the starter side of the block over real close and at the bottom of the cyl where they break a chunk out. sometimes a crack extends out of that area up to the into the cyl.
the only other spots I've seen them crack is on the head gasket area towards the PTO end of the crank. they like to blow the head gasket in that area and for some reason the 14 block cracks there pretty easy. I've also seen the 14 block crack at the cylinder the 3rd cooling fin down. You can usually see the cracks so just look it over close
Old 04-14-2015, 07:54 PM
I assume the block can be magna fluxed to check for cracks?
Old 04-14-2015, 08:03 PM
dvogtvpe's Avatar
yes they can
Old 04-15-2015, 09:02 AM
LBMAN LBMAN is offline
Default risk n boring a K321
I had just gone through the same thing getting my block done. The Mach shop I have always had do my work did not really want to deal with it. They have gotten rid of the older boring machines to make room for the new and improved equipment. it is as much of a hassle for them to set up for one as it is to do 6 or 8 cylinders.
I had to go all the way out to 40 over due to the damage done by overheating and crud. looked more like a bee hive.
good luck with your build make sure you know what age your block is , according to parts guy there are different size valves from early to late model K 321 just make sure buyer beware ..know exactly what you need. These guys know in this group. It's what they DO..
LB
Tags
149, block, bore, k321
