Old 04-18-2015, 06:03 PM
coinman66 coinman66 is offline
Default Is a Cub Cadet 1650 worth $400?
Can buy this for $400, but don't know much about this model. It's got a 16hp v twin and hydrostatic deck and transmission.
Old 04-18-2015, 06:17 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
To me, if the mower deck wasn't rusted out and no weird noises from the deck bearings, if the tires were in good shape; the transmission works, ie it goes forward and back without a problem, noises or funny smells; and the engine runs and doesn't blow lots of smoke (burning oil) I would readily pay $400.
I then would put another $150 into it and lube all the grease fittings, change the HyTran and filter, change engine oil and filter if it has one, air and gas filter, and spark plug.
Old 04-18-2015, 06:25 PM
What would a Hytran fluid and filter change cost me? I actually think I might be able to get this mower for $300. I drove it around his yard with no unusal noises?
Old 04-18-2015, 06:28 PM
Billy-O's Avatar
Billy-O Billy-O is offline
The tractor was repowered with a different engine.... so the engine is not an original. Originally a single cylinder K341AQS Kohler. If originality of the 1650 isn't a serious issue for you, then at least consider the workmanship quality as far as the tractor had been modified for a different motor.
Plow blade
#2 Cart
QA36 snowthower
Old 04-18-2015, 06:35 PM
Originally Posted by Billy-O View Post
The tractor was repowered with a different engine.... so the engine is not an original. Originally a single cylinder K341AQS Kohler. If originality of the 1650 isn't a serious for you, then at least consider the workmanship quality as far as the tractor had been modified for a different motor.
Yep just noticed the engine isn't original too. Game over for me. Thanks
Old 04-18-2015, 07:02 PM
I wasn't sure of that engine either. Anyway, Hy-Tran isn't cheap if you buy it by the quart. I think it was $8/qt last time I checked and you need 7 quarts. CaseIH dealers sell it by the 5 gallon pails for a lot less per quart, which makes sense if you have a few Cub Cadets.
Old 04-18-2015, 07:09 PM
Ok thanks Roy. I need some for my 123 anyway.
Old 04-18-2015, 07:29 PM
Buy the tractor and I'll trade you a one lunger, vibratin' Kohler even for your NOM.
Old 04-18-2015, 09:48 PM
X2. Just my 2 cents.
Old 04-18-2015, 10:43 PM
dale c. dale c. is offline
if the engine runs good and don't smoke it's worth $300 or more alone
