Old 04-12-2010, 08:06 PM
lesterl lesterl is offline
Default cub cadet 125
have anyone install aux hydraulic for loader on this particular model, and if how?
Old 04-12-2010, 09:59 PM
lesterl
I have a 122 with a danco loader need to figure out how I'm going to add another hydro punt and tank so I can use the tiller without taking the loader off.
Which loader do you have?
Old 04-12-2010, 10:10 PM
My 124 w/ loader has a pump driven by the pulley on the flywheel-end drive cup.
Old 04-12-2010, 10:15 PM
Matt when you get a chance how about some pics (I understand how busy you are with school) Which pump did you end up using?
Old 04-12-2010, 10:27 PM
You'll have to wait about a month...it's 1200 miles away from me at the moment, and I don't have any pictures of that area. It's a very small pump that came with the loader. I'm probably going to replace it when I put the loader on an 82 series tractor I have yet to reconfigure for use with a loader. The pump is really kludged onto the 124. It's kind of a mess. But it works.
Old 04-14-2010, 09:43 AM
how is your hydraulic pump hook up to the pulley? Is it hoohed up to the pulley on the generator or somewhere else?
Old 04-14-2010, 11:24 AM
Mine is the same way, it isn't a very pretty set-up but it works well. The hydraulic tank is made from a piece of 3" pipe and is mounted vertically on the right upright, just under the spool valves.
My Brother has been "after" me to build another one, if I do, I would very much like to use the rectangular tubing of the main supports as the hydraulic tank.
Old 04-14-2010, 03:57 PM
It's driven off the drive cup pulley on the flywheel end, as I said in my previous post. Take off the clutch shield and you'll see it between the clutch driver and the grass screen.
