Old 04-27-2015, 02:40 PM
Monkeyman2500 Monkeyman2500 is offline
Default 1650 points help
I've been trying to read and learn how to do this. Are the points supposed to close all the way and touch together. And when they are open they should be .020. Is that correct?
Old 04-27-2015, 02:41 PM
Also how do I adjust them farther apart? At the moment they only open to .015.
Old 04-27-2015, 03:01 PM
YUP...that is correct
.015 to 0.20 is a good starting point
Old 04-27-2015, 03:38 PM
Start at .015-.020 and then do the final point setting to set the timing per the manual.
To adjust, just loosen the screw a little that secures the points to the block and then put the screwdriver in the provided slots on the points. Twist the screwdriver to open/close the gap.
Old 04-27-2015, 04:17 PM
See link........ Static Timing
Old 05-04-2015, 01:36 AM
Ok, so I used the static timing method with a test light and it really helped running at WOT. I've got the RPM's up to 3250 from 2840 just with that. Now it will not run at lowest throttle setting. It runs good wot, but when lowering throttle it gets rough, and will die if I go below 1/4 of the way up. Any suggestions?
Old 05-04-2015, 02:15 AM
Tune the carb, adjust the throttle linkage..... reset the governor while your at it.
