Working on a Cub 70 with K161 engine. Need to find the original bore size so I can search for replacement piston and ring set. It is the small bore type. Thanks,Jim.
No one sells part for that smaller bore anymore so you'll have to get a standard piston for the larger bore and have it machined out.
IIRR as it has been a while since they were new, they were 2.875 for the small bore and 2.938 on the large bore.
But somebody might still have some NOS small bore stuff around. |
Thank you both for the info. Machine shop wants $285.00 to bore out. More than the owner wants to spend. My search continues. Jim.
Why not a cylinder hone and DIY? Is this type stuff still done? Not that much to take out.
Been a few years since I've had any machine work done but that seems like that shop does not want to do the job at that price.
122 original, well used. Owned since 1972 2182 new to me. Refurbished and gave to my son. Deere 4300 4WDA HST with FEL Many old Ford tractors, all gone now Couple old Ford trucks |
A cylinder hone will not straighten up the bore, if the cylinder is egg shaped then it will still be egg shaped when your done.
A cylinder hone will not straighten up the bore, if the cylinder is egg shaped then it will still be egg shaped when you're done.
Guess I misspoke, err mis typed. I had in mind a cylinder grinder such as these two. The picture is one my dad had and I've seen more than one bad cylinder brought back to useful life using it. The link is to a current version by Lisle. http://www.nationaltoolwarehouse.com...ampaign=bingPA Edit: One of these in a drill press and a small engine can be done quite easily.
Well at $285 for one hole this shop should be charging $2280 to do a V-8. I don't think they want your business. Just my 2 cents.
Think I'd find another machine shop!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Definitely find another machine shop !!!
The last K Series i had bored cost $60.00 , and i thought that was high !!! |
