Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 05-01-2015, 11:57 AM
ssechrist ssechrist is offline
Default Linamar 20 HP
I have a 2072 with a 20 HP Linamar engine in it which is basically an Onan. I'm having trouble with it acting like it's running out of fuel. It will start & run for a few seconds then act like it's gonna die. I can play with the choke & keep it running but open choke it dies & full closed choke it dies. I'm thinking the fuel pump maybe going bad. Any suggestions?
Old 05-01-2015, 02:00 PM
DirtRodHillJack DirtRodHillJack is offline
Been sitting a while, dirt in line?
Old 05-01-2015, 02:35 PM
Pull the fuel tank, clean it, clean or replace the fuel shut off valve, replace all the fuel lines from the tank all the way to the carb, new fuel filter, rebuild the carb and the fuel pump. Your dealing with a 30 year old tractor time to give it some TLC. Also check the intake manifold, as I understand it they are made in 2 pieces and sometimes develop a leak allowing them to suck air that causes running problems.
Old 05-01-2015, 03:39 PM
Didn't know about the 2 piece manifold, I'll look into that.
Thanks guys.
