Old 05-04-2015, 02:01 AM
bolivier's Avatar
bolivier bolivier is offline
Default Ratio of water to windshield wiper fluid for loading tires?
Just seeing what you guys are doing. I live in Oklahoma City where our first freeze is probably in November, and last freeze in February. Although, it did freeze once this March. The lowest it got down to this winter was 15 degress Fahrenheit roughly. My tractors stay in the garage, but I want them to be ok if I have to leave them outside. What would you do?
Old 05-04-2015, 02:04 AM
cubby102's Avatar
cubby102 cubby102 is offline
I went to wally world and got their store brand winter washer fluid. Good to like -25 or somewhere around that...ran it un diluted. I never noticed them ever freezing solid.
Old 05-04-2015, 07:09 AM
I just got 18 gals of free used anti freeze from the local auto repair place that they had from changing coolant in cars and trucks. You may want to give your local shop a try.
Otherwise I wouldn't dilute windshield fluid.
Old 05-04-2015, 08:36 AM
As the others have said don't add water, run it straight. Not sure what size tires your running but I can tell you that 23x8.50s will hold 6 gallons each so if you buy 12 gallons at $2.50 you should have about $30 into it.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-04-2015, 10:31 AM
o---o o---o is offline
When I did mine I thought about doing a 50/50 ratio since mine is garage kept and my garage stays above freezing, but I poured it in straight 100% to be sure it will never freeze since it was only a $15 difference.
Old 05-04-2015, 10:55 PM
I use CaCl2. Never freezes. Weighs more.
Old 05-04-2015, 10:56 PM
Do you need tubes with them?
Old 05-04-2015, 11:06 PM
I tube mine, yes.
Old 05-04-2015, 11:15 PM
depends on how much you like your wheels.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-05-2015, 03:02 AM
They're not my favorite part of the tractor, but I do like them a lot
